arcteryx
Supporting Vendor
Truck is an 12V 1985 BJ70. My amp meter jumps all over the place when I have some sort of load on it. I cannot have my headlights on and the heater fan on low and play the radio at the same time. If I turn the lights off, the radio works. When I use my turn signals, the meter jumps from above the line to below the normal range with no other load being used. When there is no load, my voltage meter is normal, being around 13.5- 14. With the help of this forum and my 3b Engine Manual (thanks Birfield), I have narrowed it down to 1) batteries, 2) alternator or 3) IC regulator (a.k.a. voltage regulator ).
So, I replaced my batteries with 2 new Orbitals (the main was low anyhow). Problem still exists. I then took out my alternator- looked at the brushes and they are within norm. According to the records, the PO replaced the alternator in 2002. I have taken this to two places to have tested- O’Reilly and Auto Zone and they are unable to test this b/c they do not have a female fit for the alternator wire. (All the employees were like "What IS that? " b/c of the vaccum pump attached ). So, now I am in a quandary and looking for advice. How can I test that my alternator is working properly? Do I reinstall the alternator and use an ammeter and voltmeter to test the IC regulator, as outlined on pages CH-9 and CH-10 in the manual? Any help/advice is welcomed.
Thanks in advance......
