first i must thank all who responded to my post and especially Dean--review
i have a lx470 2004 with the trailer package, i installed an aftermarket hitch to pull a travel trailer, when i in went in the trailer and stopped the lights remained on and the rear wipers would move slowly, and the door locks failed to work with the key.
i took it to many places on my travel but none had a definitve answer --please see the original post, to solve the problem i just unpluged the harness from the trailer, and waited to return home, went to lexus they checked the wiring and said all was well, but when i got home the lexus electrician emailed me and asked me to perform a test or i could return and he would do it, simply the test was use a spare battery and connect it to the power terminal that cmes from the harness on the car and see if the problem could be duplicated --it was --meaning the problem was in the car,he pulled the wiring diagram and found the problem, the relay was closing but this was in the design, only an 18gauge wire is used in this power feed, also he told me that if my car battery was low this circuit would allow the starting battery to draw power from the trailer battery and this is a 18 gauge wire which could pose a fire hazard, he installed a new harnes with a 10 gauge wire that goes through a solenoid that is activated by the ignition, --- end of problem-- i hope -- brought it home connected the trailer and all is well. they said they would inform lexus. it seems that some other owners would have noticed, but how many pull a travel trailer?
i do have the towing schematic which the electrician copied for me, again thanks to all ---you were right --i might visit camperworld on my next trip and tell one of the techs there that my problem was not impossible.
