It appears you have a wiring problem. Somehow you are getting 12V on the WB wire. As I said earlier that needs to be ground. It looks like if you correct that then the circuit will behave as expected. Do you have WB wired to the heater switch? That would be the first place I would look. Pictures of the connectors and the wire colors would be helpful at this point.
