CenTXFJ60
You may have seen other posts I've done needing help on this truck. the short version is I'm helping a friend (@LowDown ) who's had a conversion done and the folks who sub-contracted the work lacked experience with these trucks. Brief History...Originally an HJ60/automatic (LHD) with air. A 12HT/H55 was dropped in (this part was done well). From what we've been told they fried the original wire harness and sourced another HJ60 one which was laid into the truck, but not hooked up. Fast forward to present time...I've connected most everything I can figure out and the truck starts, all lights work except both headlights, right front corner light and light's in the gauge cluster. i'm missing the dimmer switch (another mud member is sending me one) so I assume this is why the gauge cluster is not lighting up. now the headlights are a mystery. The left side has zero volts on the multi-meter but the corner light works. On the right side the headlight plug has -11.5 volts (and the corner light as well) on the multi meter. I should also mention the hazards or blinkers do not work. This is a 24V system. Any thoughts, feedback or direction is appreciated. And I will definitely ad to this thread as I go. Thanks, Jim
