- Thread starter
- #41
Appreciate it . I need to take some time to wrap my head around the relay in the ARB harness. Currently I'm hooked up without the diode and life is good. For nowIt is hard to answer without knowing exactly how your wiring is setup. The diode in that diagram is for a vehicle with a negative switched headlight (I believe the 100 is) trigger for the relay. In this case, the diode will prevent a path back to ground.
I believe you are manually switching the lights directly from the Blue Seas fuse box on the positive side and not trying to trigger the lights or prevent the light from coming on without the headlights. In that case, Relay pin 86 should go to your switch and Relay pin 85 should go to ground, which is the standard relay configuration. It sounds like you might have wired it like that since everything works and is now blowing fuses.
I use the standard positive switched relay configuration. It makes troubleshooting easier since most folks assume relays are positively switched.
Can I cash in another favor from the mud world ? I was tapping into a power source down by driver side interior fuse box an found this part tucked away but it seem like It should be clipped in .
Can someone pop their head under dash and see if they can find this denso black plastic box with blue and white wires so I can secure it.
