Electrical 101
TJDIV
UP of MI.
Mod Emeritus
UP of Michigan
Website
www.roamwherever.com
Guru's need not be concerned...AGAIN! (This simply means that what I'm posting may be common knowledge to all you experienced bastids, but it may help out some who aren't as fortunate to possess all the "Cruiser Knowledge" of the "guru's".
EZ Wiring harnesses (and Painless from what I understand) aren't that hard to work with. In fact, they're so friggin' basic that they become hard to work with.
One thing I learned from wiring my Cruiser's turn signal circuits. They need a separate circuit (wire) ran back, or you can use the "trailer converter" (which I didn't do) or you simply need to run the wire back from your brake switch and run it to your turn signals. A lot has been said about "heavy duty flashers and L.E.D's" here, well, I can't speak for L.E.D's as much as a standard bulb loading the flasher fine.
Does that make sense? Don't try to wire your brake lights, or tail lights with your turn signals. It won't work. Separate them.
GROUNDS:
Good God at the headaches a s***ty ground will cause. I ran extra grounding strips on my engine block, and used common (known good) grounding locations for 'everything'. I highly recommend doing this.
Again, sorry if this seems a little redundant, but the stuff was so easy to over look or forget about.
