Electric Fan on a 2f???
Discussion in '40- & 55-Series Tech' started by KillerPea, Mar 5, 2007.
  1. KillerPea
    KillerPea
    511
    26
    Jan 13, 2005
    Dallas, TX
    Has anyone found a good electric fan setup that will fit a FJ40 with a 2F?? There's very little room between the pump and the radiator..right at 3.5 inches. I've got a Taurus fan, but its not even close, even if I trimmed it. Any ideas??
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,305
    Media:
    17
    Albums:
    1
    620
    Oct 1, 2003
    MN
    Move the radiator forward...
    This is in the FAQ.
  3. bandy rooster
    bandy rooster
    1,935
    3
    Aug 11, 2005
    Sunny South
    this has been discussed a couple times, but the general consensus is that unless you have a V8 or other engine swap the stock cooling system on the 2F should do fine job of cooling the system, if it is indeed over-heating, adding a fan with more CFM is only a bandaid to a problem. There is obviously something wrong with the cooling system that is it not up to the task of doing the job...
    but this is speculation, give more detail in why you need the electric fan..
  4. camcruiser13
    camcruiser13
    6,978
    Media:
    3
    Albums:
    1
    28
    Jun 22, 2004
    sittin on the couch in UT
    there was like three threads last week, moving the radiator is probably your best bet, not hard. more of a pita
  5. KillerPea
    KillerPea
    511
    26
    Jan 13, 2005
    Dallas, TX
    Its not an overheating issue so its not a bandaid..I just want to change to an electric fan. And theres not really any room for me to move the radiator...I've got a radiator hoop that fits too closely to allow any movement. If noone has found a fan that fits well yet, than I'll just do a little more research and let you guys know what works. No problem.
  6. camcruiser13
    camcruiser13
    6,978
    Media:
    3
    Albums:
    1
    28
    Jun 22, 2004
    keep us posted on what you do and get pics and write it up. good luck
  7. Degnol
    Degnol
    8,121
    Media:
    16
    Albums:
    1
    19
    Jan 22, 2003
    Kansastitty
    You know that the whole "hoop" moves fore and aft? I dont know if it will give you the room you need, but there is about an inch of movement, at least, and could be modded to allow more. The limiting factor will be the bib. There are two studs on the bottom of the core support("hoop"), just loosen the nuts and slide it forward.
    GL
    Ed
  8. KillerPea
    KillerPea
    511
    26
    Jan 13, 2005
    Dallas, TX
    I finally took some pictures and several people wanted me to update the thread with what I found. For the last year, I've been running a SPAL electric fan and it works great. No overheating issues, however the fan definitely runs when I'm crawling. I used the SPAL universal mounting kit which was great. The engine is a 78 FJ40 with the short pump and oil cooler. I think that you would have to change over to the short pump if you don't currently have one to use this fan. Crappy cell phone pics...but its all I had.
  9. joeyg1973
    joeyg1973
    911
    Nov 23, 2007
    East Hanover, NJ
    What SPAL fan? Saying you got an electric SPAL fan is like saying you got a Toyota.
  10. KillerPea
    KillerPea
    511
    26
    Jan 13, 2005
    Dallas, TX
    16 inch. Feel free to go to the Spal website and match it up with the pictures.
