Thanks for all the help that you have been giving w/out even knowing. I just started resurecting an 84 fj60 that was parked for 11 years. It's running, but rough.
The egr vacuum modulator's plastic top is partially melted. There has been no fire or excessive heat so I can't understand how it could have melted from the outside. I'm not sure if it is functioning correctly. Is there any easy way to check?
I suspect water in the fuel tank. Called two local dealers today and found that the open recall on the fuel tank is not being honored anymore... bummer.
This cruiser only has 38,000 miles on the speedometer and needs to be roaming the rockies.
thanks, griff
thanks, griff
