Need the Toyota locking nut part number for the egr plate at the intake manifold? There are 2 nuts. Similar to the 3 exhaust down pipe nuts but 8 mm. Thanks.
this is what the parts diagram shows for the FJ60. In the corresponding location on the intake manifold it shows studs, so a "nut" seems correct, but on this drawing Toyota calls it a "bolt". Part number is 91611-80812.
@ToyotaMatt can set you up
They are definitely nuts. Not bolts. I looked at the diagrams and see the same thing...bolts. The kit is nice but I only need the two lock nuts. I have looked at your website before. Very nice stuff. These are the nuts I am looking for.i have updated KITS using Modern TOYOTA Genuine parts hardware , LET's get out of the flintstone era and into the Jetsons if we may ....
longer TORX drive studs and better locking 8mm nuts that are also are serviceable down the road
please see links below
it's simple : OUT with the old In with the new is a plug and play kit for @Seth S and You ..........
LINKS for your review :
EGR Inlet #1 Gasket Repair Kit Special TORX Studs and Self Locking Nuts OEM Toyota Parts Late Model FJ40 FJ60 2F 1/75-9/87 - VintageTEqParts.com
EGR Inlet #1 Gasket Repair Kit 2 Special TORX Studs and 2 Self Locking Nuts OEM Toyota Parts Fits Late...vintageteqparts.com
EGR Inlet #2 Gasket Repair Kit Special TORX Studs and Self Locking Nuts OEM Toyota Parts Late Model FJ40 FJ60 2F - VintageTEqParts.com
EGR Inlet #2 Gasket Repair Kit 2 Special TORX Studs and 2 Self Locking Nuts OEM Toyota Parts Fits Late...vintageteqparts.com
No I am desmogged and my pcv vents there. I just need the 2 locknut's. They are 8 mm with a 12 mm head. I have these there now. Somewhere along the way I stumbled across a website ih8mud and developed an unhealthy desire to have all even number bolt heads and oem parts when available. It's really a sickness I think.ok
then all you need is the egr kit then ?
Thanks. I appreciate the feedback.my 2 updated lock nuts are designed and engineered to work with the included longer TORX studs NOT the original short studs ..fyi
Thank you all. You have been most helpful as usual. I have what I need now.You don't need a self-locking exhaust nut on those. JIS 8mm x 1.25 nut with a lock washer.
Or, is you want the Mr. T:
90178-A0062
