I had to drive from Southern Utah to Salt Lake City today for work and decided to take the FJ62.
It was around 100 degrees today, AC blasting, engine pretty hot, lots of shifting to 3rd because of wind and hills.
2 hours in all of a sudden the engine shut off. I pulled to the side, checked the fuses under the hood that are now in a Blue Sea box with regular fuses and the EFI fuse had blown.
Since I've been doing a lot of work on the car recently, I had all my tools and spares, fuses with me.
I replaced the fuse, tried to start, then the EFI fuse in the fuse box inside the car blew....
I upped it 25Amps, it started and I rushed to SLC because I didn't want to be late my meeting.
On the way back the same thing happened. 2 hours in, car died, even a 30amp fuse kept blowing.
I spend 2 hours by the side of the road going over the wire harness wearing a suit...
I then hard connected everything with no fuses and after much cranking, she started back up and I made It back home, with the car running rough.
What stood out is that every 3 seconds or so, when idling, something seems to short... and the RPM would take a hit. A pretty severe dip to around 300, then back to 700.
I'm planning on going over the whole harness, but is there an area I should start looking at? Is there a known weak spot like with the 80 series?
With the recurring dip in RPM, could it be a wire going to an injector? the EFI itself?
Can the EFI relay cause the fuses to keep blowing?
Thanks guys.
Thanks guys.
