Effed Around With Sensors and Now I'm Droppy
DownTheRoad
GOLD Star
Santa Fe, NM
A month or so, I tried the sensor lift at all corners as I was experimenting with ride handling. Yesterday, I adjusted the sensors back to the original positions and now the truck sits really low on the passenger side front. I also get the blink Hi or Lo, it seems to go high, but never really goes low. I shut it off, and it shows N, but it looks to be in Hi. I drive around 30 minutes, shows N, but the passenger side front is noticeably lower and sponger. I've tried all the tricks to get it to reset, including jumping up and down on corners, rapidly hitting the height control switch up on startup, etc. I've also checked fluids and open fill valve, no air escaped.
Any ideas?
Anyone have good links to accumulators, fluid, tech stream cable? I figure what the hell.
What’s the fluid level in the ahc reservoir (behind right side rear wheel)?
It's max.
