TurboDennis
Long story shot - my 1HD-FT has 2 coolant ports (feed and return) that were previously used for ACSD (which has been deleted). Currently there is a rubber line connecting the two ports, creating a loop.
I would like to route that feed line somewhere else (to use for a heat exchanger). I want to put an on/off electric solenoid on the line to control the flow. With the solenoid closed, what are the effects on the rest of the cooling system? Is the water pump going to be stressed more since it's now trying to pump into a dead end? Would it be preferable to have a 3-way solenoid that would redirect the coolant back to the return port instead of just closing?
Another question - this line is much smaller diameter than the rest of the lines in the system. Lets say my solenoid is open. Would the coolant still flow well through this circuit, if there are other paths (with less resistance/larger lines) that are currently open (such as heater core).
