In preparation for my MT knuckles/Disc brake upgrade, I pulled the knuckles off the MT axle.
I wanted to separate the inners from the birfields and after beating on the inner-race, Teapot (Jaquin) and I tried to think of a better way to do this without breaking something.
I gave Ron Diaz @custom customs ( customcruisersfj40.com ) a call, and he told me about their birfield removal station. He described how the birfields are removed w/the weight of the inners and the momentum alone (NO hammers involved). I called Dessert Dave, and he mentioned he had heard about a method that utilizes a simple piece of pipe.
The pipe method worked perfectly...It was so easy!!
You slide the axle/birfield into the pipe, The birfield will rest on the top edge of the pipe.
Now let it fall from approx 1.5 feet above the ground (w/one hand on birfield).
The axle will pop off and continue slide down the pipe while you will be standing there in disbelief, holding a freed undamaged birfield in your hand.
Tip - I made the mistake of sliding the C-clip out of the groove before dropping the birfield and had a difficult time removing the axle afterwards. The C-clip had gotten stuck inside the pipe which necessitated removing a few inches from the pipe w/cut-off wheel.
Thanks again Jaquin for giving me a hand,
manny 72fj40
manny 72fj40
