Early / Late 85 FJ 60 How to Know
Discussion in '60-Series Wagons' started by irishrouge, Feb 26, 2007.
  1. irishrouge
    irishrouge
    5
    Mar 10, 2005
    Can any one clarify the differences in the Early vs Late 85 Fj 60 and how you can tell the one you have ? Is there a reference on the changes?
    Thx Dan
  2. sk8salomon
    sk8salomon
    2,914
    Media:
    8
    Albums:
    1
    361
    Apr 21, 2006
    Chattanooga, TN
    Here's how you can tell. Open the drivers side door and take a look. Not sure what the difference is, sorry.
  3. irishrouge
    irishrouge
    5
    Mar 10, 2005
    Thanks Can any one tell me the Differences
    I know the made som significant changes in the early Vs late but not when and not what changes
    Thanks
  4. GulfShoresFJ60
    GulfShoresFJ60
    888
    1
    Feb 12, 2005
    MS
    One of the for sure things is to check to see if you have a double cardon driveshaft up front or if it is a traditional style driveshaft and also check to see if there is a ~3" spacer behind the transmission and the t-case. There has never been any definitive answer (to my knowledge) on the official date change over from early to late model.
  5. irishrouge
    irishrouge
    5
    Mar 10, 2005
    I know my 60 was made in June 1985, so I think it is an early model. Is there some where that has a complete list of changes?
    Thanks Dan
  6. stinkyfj60
    stinkyfj60
    1,269
    233
    Apr 22, 2004
    not in stinkyland anymore
    June would make it a late 1985... Early would be in the fall/winter of 1984...
  7. Dynosoar
    Dynosoar Slightly Disturbed SILVER Star
    3,702
    384
    Feb 4, 2006
    SoCal
    I have an April '85 and it has the "late" trans and drive shafts.
    Dynosoar :zilla:
  8. notagp_afj55
    notagp_afj55
    867
    Jan 10, 2004
    Portland Oregon
    my build date is OCT/1985 but was sold as a 85. It too has
    the spacers
  9. RredFJ40
    RredFJ40
    1,300
    5
    Nov 1, 2003
    Klamath Basin
    Yours must have been right at the cutoff. October is usually the changeover date for Toyota.
    10/84 is the usual date given for Late 60s
  10. notagp_afj55
    notagp_afj55
    867
    Jan 10, 2004
    Portland Oregon
    thats what i thought too with toyota until
    i bought this truck, and have seen quite a
    few 60's with a build date of October.
  11. Cruiserdrew
    Cruiserdrew On the way there SILVER Star
    14,871
    3,482
    Mar 15, 2003
    Sacramento, CA
    The only significant change was for the 1985 model year. The beginning of that production run marked the start of the "late" 60s. There continued to be evolutionary changes, for instance the mid 86 switch to the 38mm idler in the transfer case. There are also minor differences in the 2F-I think the later ones use a different bearing to control crank thrust fore and aft.
    The same carb, distributor, smog gear etc, was used from start to finish. JimC has a really good handle on the production differences-talk to him if important.
    The only thing that is important now, is how much rust is in the body. No rust = good FJ60. JMHO.
