- Thread starter
- #21
How are you supporting, and hoisting, the tranny Via the lumber, I'm curious. I've never done anything this way, this is pretty new to me. The doors can take all that weight?I also have a February 1974, 4 speed with an early 3 finger style clutch. I’m pretty sure it came that way because I bought it in 1980. Yes, the flywheel cover plate is the inspection cover. Yes, you remove the seats, fuel tank and transmission tunnel cover. You will put a pair of 2 x 4 lumber across both doors, (windows rolled down) and hoist the gearboxes down from above, supporting underneath with your trans jack. Yes, use long bolts with the heads cut off to line it back up upon reassembly. It’s heavy and off balance, but not complicated. Also get yourself a new rear engine seal and pilot bearing.
if you have the flywheel resurfaced, I believe it’s a stepped flywheel. Be sure and mention that to the machinist.
