4Cruisers
I did a search on the FJ40 FAQs and came up dry. I'm installing an '84 H41 (from an HJ47) and '85 split transfer case (from a BJ45) in my '71 FJ40. The split transfer case includes the drum parking brake. The overall length of the new combination is only ~1/4" shorter than the '78 FJ55 4-speed/one piece case that was in the vehicle, which has early 4-speed FJ40 driveshafts. I'd like to use the driveshafts as is but the bolt pattern on the parking brake drum is like the later FJ40/FJ60 driveshafts. Will an early 4-speed FJ40 parking brake drum slip over the output shaft of the split transfer case? I know the output shaft diameters are the same on the split case and the 4-speed one-piece case because the rear seals are the same. And the shoes and other internals are the same. I'm not sure about the splines. Any insight would be appreciated.
