I recently had to pull my TC (and Tranny) to have it rebuilt. For reasons I won't go into, I had to do it by dropping the engine (i.e., removing the lower motor mounts and pulling the bolts off the top motor mounts, and lowering the transmission and securing it). This worked reasonably well, except that the engine didn't drop exactly evenly. The Starter prevented the engine from dropping very far on the right side so most of the drop (which wasn't that much) seemed to be on the left side. In any event, it was enough to drop the TC low enough to pull it out from under the Crossmember. NOTE: I have a SM420 Transmission and a 5" Advanced Adapter (AA) adapter between the tranny and TC. That pushes my TC and e-brake right up to the crossmember. There was only about 2" of clearance- just enough to allow me to pull the TC off the Transmission.
I managed to get the TC back on and everything reinstalled, BUT HERE''S THE PROBLEM:
After all of this, the alignment of the engine, transmission and TC has been (apparently) slightly altered by taking this approach. I was test driving today and I started hearing a loud screech sound of metal grinding. OH LORD! Upon inspection I noticed that the Brake Drum has shifted to the right slightly such that it is no longer centered under that crossmember hump, and it is now up against the right side of the crossmember. Holy crap!
So, the problem (and the solution is obvious): I have to get the Transmission/TC/e-brake straightened (shifted left) so that it is more centered under that hump in the crossmember.
My problem is, I'm just not that sure what is the best way to go about it. There really can't be very much play in those motor mounts. I had a really hard time getting the front (top) motor mounts to line up the first time, and I'm a little concerned about trying to move all that weight from below with jacks and levers. It seems that would be (potentially) putting a lot of stress on the engine mounts. I guess there might be more flexibility in adjusting the rear (lower) engine mounts (and just loosening the top bolts slightly), if that could be sufficient to shift things into alignment.
I suppose using a. engine Hoist to relieve the tension from the top might help, while using jacks and levers below to try and shift it.
Any thoughts on this and/or recommendations on how I might approach getting it into alignment?
