Dust shield repair or replace?
Burbank, CA
What should I do?
I think it was caused by the OME uca rubbing against the dudt shield at full DROOP.
Other side had dent but no hole.
I'm Installing SPC uca do will have this problem in the future.
JunkCrzr89
Competent Ignoramoose
Colorado
That’s wild. If the shaft isn’t damaged, then not really a big deal, though. If you clean off the surrounding area, slap on a couple layers of Gorilla Tape, and spin the cover 180 degrees, it would prob last a long time.
Burbank, CA
I have installed the japan 4×4 spacer on the lower shock bolt. Maybe the cause.
