Dust seal and oil seal
Central Florida
I am replacing front rotors on '76.
Is the Dust Seal normaly replaced when removing the hub? This is the metal plate with a rubber inner seal. top left in first pic...
https://forum.ih8mud.com/showthread.php?t=68912&highlight=seals
Looks like this might help keep water out but the old one looks ok.
Is it recommended to replace Oil Seal and clean inner bearing? (this is the one not shown in FSM for some reason)
Thanks for any insight
No, but it is if you remove the knuckle (as opposed to merely removing the hub). If you're just doing the hub, there's no need to remove the spindle bolts.
If you're in there anyway, you might as well replace the oil seal in the inner side of the hub. You'll have to remove it anyway to get at the inner bearing.
Poser
Oh...Durka Durka Durka.
s-Moderator
Supporting Vendor
MN
If this peice looks fine, and is not tore up or damaged, I have re-used them when only doing a bearing/lock out service...
Good luck!
-Steve
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
