DUI (Davis Unified Ignition)
Rockwall, TX
THe vacuum line on the bottom of my carb(in between the carb and head, at the base) that is running to my DUI is not pulling a vacuum. Does it matter where the line is running from the DUI, as long as it is pulling a vacuum? Thanks!
It sounds like it's ported vac. It wouldn't be drawing vacuum at idle....if that's what you're referring to. Under load it would pull to adv. the dist.
