Duh-huh! Do I remove oil before..
Correction 7 deg BTDC for #1
I removed the spark plugs so I could spin the crank easier. I think I got a socket on the main pulley nut.
Spin until you have the flywheel mark indicating 7 deg BTDC (the hole in the flywheel). Your distributor rotor should about 30 deg CCW from straight up (pointing at where the #1 plug wire attaches).
Sounds difficult but it's not.
2F manual gives a good run down. Why are you removing it?
Good luck.
Gordo
I bought another 60 and the PO says the distributor is cracked. So I pulled mine out of my crap 60 to drop in. I had a hell of a time getting mine out-1/2 can PB Blaster- I just hope I don't have too much trouble replacing the other. I'm ready for my new Cruiser. Thanks again, Gordo.
Todd
