Dual stock tire carriers
Status
Not open for further replies.
Monroe, WA
It doesn't look like it's going to work out trying to put a 36" spare on the stock carrier, so here goes. This is my somewhat ghetto version of a double swing out rack.
The right one is from a 72 IIRC, and the left is from a ~75.
The right one is all straight, and was disassembled and painted gray (ok job). I cleaned up the hardware, but never finished the job, so it's got some surface rust on it. The latch is loose, hence the hitch pin keeping it from unlatching. I think it could be repaired with some weld on the hook.
The left one looks like someone backed into something with it open. That's the only explanation I can come up with for the slight crease along the top edge. It doesn't really affect it in any way, but it's there. I straightened it out as much as I cared to bother. It looks like the factory beige paint is in good condition overall, but I've long-since ditched the carrier bracket. You can have my ghetto-fabulous hi-lift bracket if you want it. The latch is in in very good condition and holds tight with no slop, but I had to create new holes for the mounting bolts and I made them to fit.
I'll probably need to keep the ghetto-fab license plate bracket.
$30 each? or $50 for both? I really don't want to ship them, so local buyers get priority.
If you put a spacer between the swing out, and the tire mount you can fit your 36"...
just trying to help...
Edit: Another addition is to add a crossbar from swing out to swing out to tie them together and it'll be beefy... (obviously must be removable so you can open them)
I have a dual swing out tire carrier in Lynnwood if you're interested $200
I had a 35" on there, and it worked great. I'm mounting my spare inside the vehicle from now on
Right now that's about #36 on the list :lol:
Thanks anyway. I'll keep that in mind if/when I ever get around to that project.
Pics of driver-side carrier-
In the profile pic, you can tell that's it's still not totally straight, but it was good enough for me at the time. When I got it, there was probably a 10* bend there.
Status
