dual FJ40 tanks, one filler neck! (1 Viewer)
65swb45
Elder Statesman
Supporting Vendor
Website
www.marksoffroad.net
I am finishing up a lift kit on a 1974 FJ40 that has, as the title indicates, two fuel tanks running off the single stock filler neck. The was apparantly done in order to avoid putting a second filler neck on the outside sheetmetal of the truck.
The stock filler neck has a pipe welded into the side of it, which then proceeds about a foot into the interior of the bed, where it goes through a new hole in the floor to the underside of the tub, with a long horizontal hose to the tank.
Here are some pics:
Please note that I DID NOT DO THIS WORK, nor would I offer to. I just thought it was an 'interesting' modification to post a thread on.
Best
Mark A.
the electric pump it's for transfer the gas on the aux to the oem or the gas gauge work separate for both?
Hi all, I am new to the forum and the 74 FJ40 in the photos is mine. The electric pump assists to purge out of the fuel line when I switch from aux to the original tank on the go. The pump needed to be repositioned, as it was pinching the hose and causing a bad leak. This install used a large marine fuel hose which was replaced after these photos were posted by Mark A. I opted to use the original gas gauge with the two sending units and it works. Most of the auxillary fillers I have been told usually splash gas when turning left, plus I didn't want to cut the external body for this extra tank. I will post some photos of my vehicle after paying up here.
I like it.
