Juan, long time no see! Hope you’re doing good. You can’t run a National Luna smart relay dual battery kit with a DC to DC charger like the Redarc BCDC concurrently. lmk If you need some assistance with the setup.Wow this reminded me about my photoman kit I've had since 2008! fast forward to 2018 when I got the conversion harness.
Got to decide on this mod too. I am running dual X2 power batts with a national luna system. Recently picked up a redcarc BCDC but it doesn't play nice with the national luna kit. I have to rethink my setup as well.
Thanks for those stock alternator readouts. That sounds about right with what I have seen also. What I am getting at with the multiple simultaneous amp measurements is to see if the alternator current is keeping up with your battery discharge. It Would be cool to see in the “2000rpm with lights and blower at max” scenario, if you are netting positive or negative and by how much on your start battery. I use a multimeter with clamp ammeter all the time on my truck to see things like this. thanks againGot home in time to do 1 of the 3 measurements - Alternator output...
At idle with no accessories running - 19.6A
At 2000rpm with no accessories running - 20.9A
At idle with headlights and blower at max - 47.8A
At 2000rpm with headlights and blower at max - 52.9A
These readings were taken with the 2nd battery disconnected from the system.
For the other measurements I need to swap the other sensors to the -Ve side of the battery - at the moment I have them monitoring specific +ve feeds.
**edited to correct readings to Amps..
Cool thanks man!Juan, long time no see! Hope you’re doing good. You can’t run a National Luna smart relay dual battery kit with a DC to DC charger like the Redarc BCDC concurrently. lmk If you need some assistance with the setup.
