Dual Battery Electrical System Design: Master Thread (Index Thread)
jaymar
SoCal
This thread is intended to index (primarily) the most thoroughly detailed threads on multi-battery electrical system design. Meaning, not the "Hey I just installed all this great stuff isn't it cool!" threads (and yes it is cool btw) but more the "This is how I designed my electrical system; here's the math and how you calculate amp draw, the wiring diagrams / schematics, the parts I used and the photos" kinda threads that are most useful to those looking to do something similar. With occasional forays into specific related areas (like washer-relocation). Part of my reason for doing is that I want to wire things up for serious overlanding while swapping engines--and I don't know squat about wiring. Zip. Zilch. Nada. Bupkiss. So I'm looking to learn from those who've already done what I want to do. I did try to shortcut by looking up ICON's former electrical engineer, but he is, shall we say, unavailable for the foreseeable future.
Note: Some links pointed to individual posts rather than OP; that's been fixed. Links may be reshuffled later. I may add a solar (or other) section if I find enough links.
Feel free to point out relevant threads, and I'll add them to this first post as we go--ultimately winding up with something like my earlier index threads:
=============================================================================Begin --Inigo Montoya
WASHER BOTTLE RELOCATION
[Looking for Delta and Slee kit thread links. Also, @NLXTACY has mentioned a bladder sitting atop a fusebox IIRC, and also "The good news is there is an alternative JDM Corolla two piece washer bottle that sits inside the driver’s side fender. There are one or two threads on it and I have it installed myself. Frees up a lot of room." Links, anyone?]
MOUNTING COMPRESSOR WITH BATTERY
MISC
Voltage and current monitoring setups in conjunction with the installs would be great, and hugely helpful in both day-to-day operations monitoring and troubleshooting.
Once an electrical baseline is developed using the monitoring, anything that generates an 'out of spec' reading can be quickly identified and isolated - provided the design of the install allows you to do so, and quickly.
In short, the monitoring can absolutely help prevent catastrophic failures which will destroy a rig in no time.
To this end, and if interested (and something I've been wanting to do for a while since my install), I'll get to documenting my monitoring setup and offer it to the project.
Yes there are turnkey (read expensive) solutions, but mine uses the far less expensive lcd/shunt kits available on Amazon and other places.
Absolutely; post it up and shoot me the link!
Very timely!
I just finished relocating my washer bottle and installing second battery. I fabbed up relocation brackets myself and the battery tray is similar to what I made for the driver side. Only difference is integrated ARB compressor mount.
Electrical is simple and straightforward, with continuous use solenoid wired to connect both batteries when the engine is running. All parts of the system are rated to 350A+ continuous use, enough for jumpstarting and winching.
A few pictures. Will take one of the finished product tomorrow.
I have been contemplating putting a video together on wiring up a 4WD (specifically my 80 series) covering the basics right through to advanced circuits... How soon are you getting started?
Just the absolute vast majority of wiring jobs I've seen are very below par and can be done much better with a little effort, a few special (but cheap) tools and some patience.
I am also a fan of using individual specific components vs "all in one" units which are very very expensive (Like Redarc, which make good stuff but can be done for a lot less money).
Sounds great. Right now I'm in the parts-hoarding phase for engine/tranny rebuild and engine bay upgrade. Targeting this summer for the actual work.
