Drum brake wheel cyls TLC
Discussion in '40- & 55-Series Tech' started by brider, Mar 2, 2007.
  1. brider
    brider
    609
    Feb 9, 2005
    Back to the drum brakes.
    I asked this question here before about lubing or not lubing the pistons(the steel parts that push against the brake shoes) within the cylinders. The closest answer I got was to change fluid often to minimize water absorbed into the fluid, thus rusting the cyl walls.
    But my concern is the interface between the steel parts and the steel cyl walls where the brake fluid NEVER TOUCHES. When the brakes are adjusted properly, the little rubber pistons in the cyls move very little, so the majority of the steel piston is in bare contact with the bare steel walls of the cyls. The only seal is the external rubber boot on each end of the cyl, and it's not a great seal.
    So shouldn't I use some anti-sieze or light grease to protect the bare steel sliding surfaces?
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,374
    Media:
    17
    Albums:
    1
    726
    Oct 1, 2003
    MN
    There really should not be any ‘bare’ steel sliding surfaces exposed, since the rubber boot will keep anything out of that area.
    Lubricate the threads on the adjusters and call it good.
  3. splitshot
    splitshot Head cook, Bottle washer, and Peace keeper. SILVER Star
    7,090
    Media:
    11
    Albums:
    1
    1,493
    Nov 17, 2006
    Rodent Central, Az
    I usually put a dab of anti-seaze on them.
  4. Gundy
    Gundy
    3,191
    10
    Jan 2, 2003
    Dweller on the Threshold
    I agree with Poser on this. I've never heard of the piston sticking. Perhaps
    this would happen on a poor cruiser that rarely gets driven. ;)
    The adjuster is a different animal. They WILL seize. Anti-seize is a solution.
    I'd guess it wouldn't hurt to grease the "exposed" piston area. I just don't think
    it is needed seeing how it's "booted".
  5. John McVicker
    John McVicker SILVER Star
    2,279
    601
    Jul 11, 2005
    Big Pine, CA
    Wheel cly. pistons will certainly sieze. But the solution is not to lube the pistons. The solution is to keep the moisture out of the clys. & you do this by changing the fluid regulary (brake bleeding).
    Not unheard of to have to literally remove the pistons w/a wooden dowel once siezed due to rust. Change brake fluids as part of regular pm & you won't need to worry.
    Good luck, John
    Edit: And yes of course, use anti sieze on the adjusters. They can/will also freeze w/o anti sieze.
