Is it bad for the engine when you've been driving with a blown o2 sensor? All I notice is crappy mileage and a little less power.
parabola said:Carbon buildup and fouled plugs are a few things you'll see. I'd guess you could also clog your cats...
Your truck isn't fueling itself properly. You should really fix this ASAP.
tucker74 said:Eventually you'll carbon up the whole top end and still need to replace the O2 sensors Replace them and use some Seafoam and Redline "Total Fuel System Cleaner" before you end up spending more money. Prolly gonna want new plugs as well -
Tucker
You'll definately see rough idle. Vibration in the cab? From engine misfire maybe?nyk438 said:I'm planning on doing that in the next 2 weeks once I get the cash. Replace the plugs, air filter, o2 sensor, and use the fuel system cleaner. Just making sure but a blown o2 sensor can cause a rough idle with vibration in the cab right?
parabola said:You'll definately see rough idle. Vibration in the cab? From engine misfire maybe?
