Driving Lights/Fog Lights brackets? (1 Viewer)
Israel
Hi All,
Looking for specific brackets that will allow to install additional lighting on a stock 2016+ bumper , preferably without drilling at the stock bumper.
Thanks,
Aifer.
I was looking for something similar and found a relatively inexpensive and easy solution to run some stealth pods on the inside of the grille. I do not have any interest in cutting my grille so that is how I approached this project. I plan to add an additional set of pods in the future. I believe you could also run a light bar using this setup. It does require you to drill the metal grille insert support but this mod is otherwise minimally invasive. Of course you also have to run the lights but that is a separate discussion depnding on the goal you are trying to achieve with the lighting.
I used these Bronco ditch light brackets from AMZN because they were a perfect fit and didn't require me to fabricate my own bracket. I actualy took some pics to document this project but haven't got around to posting it. Sorry I cannot remember what size drill bit I used but that is easy enough to figure out if you decide to go this route. Pics to follow.
You can see where I drilled then mounted the brackets. All stainless for corrosion resistance. Very happy with the light output considering I didn't cut the grille.
