driveway pic - ome medium installed today
Worked on this all day so thought I'd post a pic. Got a little over 2 inches lift from it.
SAWEEEEEEEET ~!
Bet that feels good huh ?
:cheers:
Looks great! Are those 285's? How's the ride? How was the install process?
Sorry for the questions - I'm planning to do the same this summer.
That looks great! Congrats! I too am curious if those are 285's? It seems to be sitting nice and level (no stink bug action) did you use any spacers? Any comments on the change in ride and handling? I have yet to drive a lifted 80 so I am curious as to the change. Whats next on the list ...... there's ALWAYS a "Next" :)
:cheers: - Nate
305/70's. Ride is less harsh with less lean but didn't notice a night and say difference. Install process went smooth. Wasn't that hard which says a lot because I'm a 1-banana mech and that was probably the biggest LC project I've taken on. Upper DS shock bolt was a bit tough to remove and I never could get the torque wrench on it when I put the new one in. I PB'd everything once about a week ago and then again about an hour before starting and paid extra attention to the rear lower shock mount bolts as I'd read they like to break. For those I followed Christo's directions and used a long breaker with gentle/steady pressure and lots of PB, worked great. Without a doubt it was great to have a friend to assist. Took about 5 hours. I ran out of time and had to put off the caster correction bushings for next weekend. Without those the steering isn't all that bad but does act as if I was pulling a heavy trailer or loaded down in rear, making the steering feel light.
Looks nice. I switched about a month ago and am real happy. I am running 285's. Nice job. Even though I rebuilt the front axle in my garage, I chose to have Slee install mine.
:cheers: - Nate
No spacers although I had some OME 10 & 5mm on hand I decided to first see what it looked like without them. When I installed it the tank was on empty and the 3rd row was out it looked a bit stinkbug. Put the third row in and filled the tank and it leveled out nicely.
Fr shocks look silver .. they OME too ?
Dagnammit ~ I thought there was a bling special issue coming out now .. ;p
Moj,
What did you torque the top and bottom of the shocks to, 51 ftlb? I wasn't sure when I did mine last week. The OME instructions didn't say, and I think those lock nuts fool the torque wrench.
I just split the DS top shock nut for sanity sake.
hobbes
MoJ,
That's sweeeeeeet looking rig! Which OME did you go, Medium or Heavy? Rig really looks awesome. :D
4x4CPOSEADOG said:
MoJ,
Christ , you did read the thread title , right ??! :flipoff2:
nice! you are taking the RBs off, right?
:D
Ooopss sorry, my bad! :flipoff2:
Nice set up you have there! I like how the 305s look on the truck. Plus no need to regear going 305s. Let us know if you put on the spacers and if there is any difference. I am debating which spacers to go w/ right now. Anyhow, great job on the setup.
:cheers:
hobbes said:
Moj,
hobbes
top/bottom of front, and top of rear only, just zap 'em with the impact until the bushings are about half or 2/3 normal height.
>>What did you torque the top and bottom of the shocks to, 51 ftlb?<<
Just torqued them to what ever the FSM said.
>>I think those lock nuts fool the torque wrench.<<
Is this true? If so, any guess on how much they distort the reading?
>>nice! you are taking the RBs off, right?<<
Dunno yet although they'll prob. be taken off for me during the poker run in a few weeks.
