Ok, so I have a 2002 LC 253k miles. When I purchased it 2 years ago I could hear a hum coming from what I thought was just the the fact that the vehicle has an all time 4wd system.
I purchased a 98 for my son and noticed that the sound was not there.
Recently my mechanic was was doing some work on the vehicle and he mentioned the noise after a test drive. So he put it on the lift and a fresh leak was coming from the rear carrier pinion seal. His opinion was that the rear pinion bearing was going out which caused both the sound and then eventually the leak.
I found a local rear carrier/diff assembly and he and I installed it last night in 3 hours. Went on a test drive and the leak is gone with the new seal, but the noise is still there.
It is definitely not a whirring from a bad alternator or anything electrical. Not a clunk, or grinding.
Anyone here have a similar issue or ideas on how to figure out where it’s coming from?
Thanks in advance all. Hope you guys are doing well.
Adam
Adam
