Driveshaft Question (1 Viewer)
Columbia, SC
I have a 1984 FJ60 and bought a driveshaft off MUD from another 60 and it did not fit. Does anybody know what year they changed the u-joint coupling size? Thanks for the help!!
-FM
FJ60Cam
Supporting Vendor
Memphis, TN
I don't know the month, but late '84 to early '85 they made quite a few changes like that.
Columbia, SC
Can you buy the flanges to fit the newer shafts to the older trucks? I just spent $125 getting it cut down to fit after the conversion and tehn it wouldnt bolt up. I didnt even think about checking beofre hand. IDIOT!
Cruiserdrew
On the way there
Sacramento, CA
You could just re-drill your existing flanges for the new pattern, and I think Cruiser Outfitters sells new flanges with several different hole patterns, but they are not cheap items. If that's the only mistake you ever make on your Land Cruiser, you are way ahead of the rest of us.
dgangle
total rice
Heart of Dixie
By chance is this a double cardan front driveshaft? If so PM me if you want to sell it. I could pick up to save you the trouble of shipping.
Poser
Oh...Durka Durka Durka.
s-Moderator
Supporting Vendor
MN
Knock the u-joint end yokes off your old shaft that bolt up to your old differential and transfer case companion flanges, and put them on your new drive shaft....the u-joints are the same.
Not that big of a deal really.
:meh:
Columbia, SC
The truck was without a drive shaft when I got it and I bought another one off an 87. I need the proper couplings in orer to make that work, that my problem. Does anyone have another drive shaft they would like to sell that would fit my 84.
I believe it is a double cardan shaft. If I dont use it I will be happy to sell it to you. I will keep you posted.
Thanks for the help guys.
Poser
s-Moderator
Supporting Vendor
MN
A 1987 60 series would not have had a double-cardan front or rear drive shaft.
The were not ever used in the rear from the factory, and in the front only until 07/84, 08/84 and later did not have them.
:meh:
Hit up Trollhole; he should have the driveshaft parts you need.
Cruiserdrew
On the way there
Sacramento, CA
Frankie-A later driveshaft would not be double cardan. if it is, it's an earlier shaft.
Poser is right-the best thing would be to find the least expensive 75-84 shaft you can find, and swap the yokes. I have a bunch of spare shafts, but shipping from here would cost more then they are worth.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
