i'm in the midst of a spring-over on my '74 fj40, i'm using a 3 speed transfer case, and my 3rd members are from a fj60, i cut and turned my front axle and tilted the rear pinion- both are pointing at the transfer case output shafts, from what i understand i need a cv joint on the transfer case end of my driveshaft and a regular u-joint on the 3rd member end, i also need long travel slip yokes....does anyone know of a shop that can build such a driveshaft? i've made a couple of calls and haven't had any luck yet....i''ve read up on this in the tech section and i know that some mini-trucks and fj60's had cv joint shafts, but those aren't going to mate up to my 3 speed transfer case are they?
thanks!
thanks!
