Driver Side Mirror - FJ80
Cave Creek AZ
1994 FJ80Evening all - who can tell me whether it's possible to replace the mirror on my FJ80 without replacing the entire kit n' kiboodle? The much documented rattle eventually led to two of the three retaining holes snapping off. Otherwise - where should I go to replace the mirror? Many thanks.
NW
You can replace the mirror just itself. The dealer has it, however, I think if the retaining back plate is your problem then I think you need to replace the whole mirror. I hope this help.
Cave Creek AZ
Thanks, the retaining back plate is the problem. Checking around - so far I have found black and chrome replacements (probably aftermarket) for around $100. I'd prefer an original Toyota burgundy if possible.
TX_TLC
Texas
You might try RTV silicon to put them back together, mine is holding on just on hook and RTV - no rattles and still have full movement of the mirror.
Cheaper solution...and lots of info about it on here.
OZCAL
Queensland and California
I had a rattly mirror function fine for many ten thousands of miles with some keenly applied liquid nails/paneling adhesive kind of gunk at the broken mount points.
Cave Creek AZ
Much belated thanks to everyone. I'll get on the silicon solution. Right now I have duct tape holding everything for almost 9 months!
Kevin
CJF
Kevin
LOL!!
Oh well; closure is always good.
Welcome back,
Curtis
