Driveline vibration (1 Viewer)
Ohio, Illinois
Ok , so took the Taco into the dealer yesterday so they could complete TSB-0249-12 to address the driveline vibe from a dead stop .
Dealer installed part number 12371-31250 - insulator, engine . Read rear trans mount ...
Mechanic stated on paperwork that the vibe was gone - wrong numbnuts ! It is still there , albeit a bit less . Plan to return a call to the service writer today for a follow-up .
Personally, I think it's mostly the damned springs on the rear axle , a classic symptom of spring wrap deflecting the pinion angle upwards and causing the driveshaft to bind the u-joints . This truck does have the stupid 3-leaf packs which ride ok at best , haven't had a chance to do a good load test yet but will one way or another this week . The Tacoma world forum has an extensive library of posts dealing with those rear springs and seems like if you complain enough they will replace them with a 4-leaf pack . BTW, this happens at 1/4 or more throttle input , basically normal everyday driving in traffic .
Anyone else have any feedback on this issue ?
It almost feels like a trans shudder at takeoff , but it's not . No evidence of burnt fluid , ect and it works great if you just stab the throttle , or just burn the tires ...
I do have an idea , maybe I'm nuts here but ....
How about taking a GoPro cam with a good clamp mount and taking a shot of the pinion angle change as the springs load up under acceleration ? It would at least prove my theory and offer video proof of a weak spring design so at least others would have more ammo to work with against the manufacturer . Getting sick of poorly designed vehicles that these big companies produce with known issues and their habit of blowing customers off to save money to maximize profits . Would never expect this of the Japanese but welcome to our "modern world" .
Just as a backround note -
I've built some pretty serious dual-purpose 4x4's in my life - the last was a 10" lifted Samurai on 33's , sprung-over leaf springs . Had the same issue at takeoff under even light throttle - the springs would s-bend and change the pinion angle severely enough it actually bent a set of springs . Made up a new pack and installed a 5th arm style anti-wrap bar , problem solved and wheeled the snot out of while a daily driver (read ONLY driver) for nearly 10 years and 130,000 miles . 40" of articulation at all four corners so I do have some experience here .
Love to hear what others have done , what do you folks think about the camera idea ?
Sarge
My 05 double cab did it. 4.0/auto 4x4. As best I could tell it was axle wrap but with 112k on it when I bought it there was no chance of getting Toyota to do anything about it. It didn't really bother me that much but if it had been a new or near new truck it would have. What did annoy the crap out of me was the slight driveline vibration the truck had at 60MPH or so. I drove 3 other similar 4.0/auto trucks and they all did it too. Six speed trucks and my previous 05 4 cylinder 4x4 did not. The 4 cylinder truck didn't have the axle wrap issue either. That one I bought new.
I have exactly the same problem as the OP, on my brand spankin' new 2013 Tacoma Access Cab TRD-OffRoad 4X4.
Driveline vibration under acceleration from 10-20 mph. Been to the squealer twice, they acknowledge the problem but say that there is no fix. They say that TSB 0249-12 has been obsoleted. Not because the problem went away, but because the repair suggestions DIDN'T make the problem go away.
Where does that leave a sad sack like me, who just shelled out $30K for a truck? Well, it leaves me wishing I'd bought a Nissan is where it leaves me. Well, no, it's not that bad, but pretty damn close.
I can't believe Toyota is stumbling over its dick so hard in this instance. Toyota has always stood for what's good and right in the automotive world. They make good stuff, and when they don't they clean up their messes. Or at least they used to. Not so sure any more.
Pissed? Yes, I'm livid.
Got suggestions how to move forward? Me, no. You ????
id be so mad at toyota as well
I have a toyota tacoma 1998 4x4 and when my center support bearing went wore out i had alot of driveline vibration.. idk if the new tacos have a csb but if it does check it out and make sure its not worn..
Most likely its the leaf springs tho. i hear those leaf packs are not very beefy and can allow some axel wrap. Id take it to toyota and tell them to fix it and to replace the leafs and see if that solves it.
BTW if u went with nissan the whole truck would be crap lol ;)
:my 2cents:
thinking that an option might be to take it to a shop that does leaf spring work. Not sure if adding another or replacing 1 or more could resolve the issue.
I used to get my 1/2 ton chevy work trucks in to add 2 leafs to the factory stack to maintain ride height while carrying a fair amount of weight.
My 2012 DCLB tacoma has the same problem new and it even had the 4 pack leaf springs. I ended up lifting it with an Ironman kit with new rear springs and the takeoff shutter is gone. I finally worked out the slight driveline vibe at 60 mph by using a larger carrier bearing drop (3/4 inch). I also learned tire balance is really critical on the Tacoma.
Man DL vibes suck! I had to jump through a ton of hoops when I lifted my '96 Taco to get it running smooth again.
