I have read many of the posts on the topic of driveline noise and vibes but need some suggestions on what the next best steps are for my situation: A vibration/droning sound at 65-70 mph+/- since installing a lift. The sound goes away immediately if I let off the accelerator, and comes back until I power up to 75-80mph.
Vehicle stats
-2003 w/205K
-Lift: Tough Dog TourFlex heavy springs rated 660-1100#- I sit 23" hub to fender in the rear, 21.25" front. 45mmrear adjustable, 53mm front
-TrailTailor Adjustable RUCA/LCA's, extended sway bar links
-Nitro Gear FUCA's
-Tires 34PSI BFG T/A K02 275/70 R18 tundra rims
-New inner and outer TRE's
- Newer OEM lower control arms
Actions taken
- Aligned rear driveshaft to match rear pinion angle via control arms (see photo)
- Set rear control arms (upper and lower) at approx 3/8" over stock length
- Greased rear DS slip yoke
Notes
- Slip yoke shows approx 3/4" of newly exposed length with the lift.
- There is minor play in the slip yoke perpendicular to the length of the yoke. (up and down or side-side movement)
Planned Actions
- remove rear DS, drive at problematic speeds (weeeeeee) test for vibes
Vehicle stats
-2003 w/205K
-Nitro Gear FUCA's
Actions taken
Notes
Planned Actions
