Im building a spring over lift for the 60. Rather than build new drive lines I was wondering if anyone knows if Boby Longs spacers work on a 60? It says on his sight for pick ups and 4 runners. If not does anybody else make them?
Cause the stock driveline works perfectly well
With the axle offset to the front of the spring and the shackle being on the back of the spring, you will not have that much extension of the rear shaft. Point it at the Tcase and use a CV shaft and it becomes even less of an issue. You can use the front CV on the rear. 60's are nice becasue they have nice LOOOONNNNGGG rear driveshafts.
