I have a weird noise exactly as you describe. It happens when I back off the accelerator while going highway speeds. And if I bounce a little because of a bridge or uneven roads, I can hear it then too. Can you give me some more info on the two bearings you mentioned?Your noise kind of sounds like a transfer case output bearing or pinion bearing. Does it happen when your going downhill at highway speeds and let off the gas?
