@Aggiesdm Sorry, but I haven't put any time into this in a while. We have had temps under 25degrees and I don't like being cold. A torpedo heater is OK for general stuff, but when you have to lay under the cruiser to do anything, that ground is COLD.
My "clunk" includes a ringing sound like a bullet hitting a hard steel plate. It is the same frequency as the sound in the video above. Because of that I don't think this is a drive-flange issue. Just going off the sound I get from playing with the output of the transfer case, I have a feeling that is where the majority of the play is. I have a feeling there will be some worn gears or splines in there.
I won't know for sure until I drop the T-Case and I'm just not ready to do that until it warms up a bit more. I'm removing the front axle/drive shaft today(its 30 degrees). After that I'm going to fiddle with the t-case and see if I still get the noise. That will isolate it to either the front axle(if he sound goes away) or the t-case(if it is still there).
My 80 makes the same bullet ping sound noise. Mine is a 95 lifted on 35's,locked and with 222,000 miles. Front axle rebuilt about 3000 miles ago and RCV chromoly axles. But mine only makes the sound when I shift into reverse and apply the throttle. It also does it more once the driveline is warmed up from driving. This noise started recently and before I had no clunks or noises prior. If I listen with the door open me in driver seat , it sounds like it is coming from the rear axle or transfer case. But mostly rear. Sometimes a couple ping bang noises. I've checked and greased everything. And changed all fluids. I did find a tiny piece of gear (pencil tip small) in the transfer case fluid. But I could not identify it? I'll be going into the rear axle soon once it warms up here or breaks. Which ever comes first. I will post my findings but will be following this as the sound described in this thread best describes mine as well.
My 91 FJ80 must have 20 grease zerks- best to get an owners manual with the pic of all the locations.so "the clunk" then is normal ? from what I summize on this thread ? mine clunks a little here and there ... thought I'd grease the zerks and see if it helps ... was just trying to figure out where all of them are ?... I assume one at each end of each driveshaft ! where else ? ... I know I know , I could crawl around and look for them , but it would be nicer to just know , ya know ?![]()
if the drive shafts are solid with no slop at all in them , am I good ?
What kit did you use when u went part time.Most of my clunk was eliminated when I went P/T
If you did it over and could only pick one. which. and thanksI have two Land Cruiser with PT one uses Marks and the other Lokka spool both with Aisin hubs
This is a common issue with diesels however, you don't realise it as the weight hides the problem.I know this is an old thread, but I think still relevant. I've got a clunk on one my rigs and have assumed it's the motor mount. Reminded me of the clunk I had on my FJ60.
How common are broken motor mounts on a FJ80? The motor definitely moves some if I rev it in neutral. I know all will move some, but I think this might be more than normal and indicate a bad mount.
To prove it:
Open the bonnet and have someone stand to one side looking at the engine.
Left foot hard on brake, select drive and give the throttle a quick blip, that's a blip! If the engine mounts have failed, the engine will lift on one side due to the torque reaction.
Check both sides, as one side remains under compression when you test, the other side will lift.
Regards
Dave
