Drive shaft throwing off grease, overfill or something wrong? (2 Viewers)
Southern California
I haven't crawled under in about 5k miles, got under there today and saw this. Is this simply the mechanic overfilling when he checked the slip yoke or is there something wrong here? How would I know?
Maine
I see that as a good thing as it means grease has been put where it should be. Likely the driveshaft compressed under a bit of articulation at some point after being lubed and pushed out a good bead of grease that no longer fit in the then compressed slip joint. Upon re entering the highway it slung and you got what you have there.
Utah
All of my vehicles that are regularly greased look like this. If the driveshaft is too near the cats (like on my discovery 2), you get to smell burning grease for the first 500 miles after a good U-joint service.
Are your u-joints serviceable? From the picture it looks like it's about time to re-service both the U-joint and the shaft.
flintknapper
Deep East Texas
Exactly Right.
This happens every time I lube either one of our vehicles. Invariably some grease gets slung onto an exhaust pipe and makes a burning oil smell for a day or so. Wifey always complains about that. I just smile.
All is good.
Gilbert, AZ
I use a product from Lucas Oil that is designed for heavy-duty use, ie bulldozers, front loaders, etc. It is designed so it will not be flung like the regular stuff. Never had any issues since using it.
Texas
Isn't the consistency spec'd by the NLGI #2? All #2s will fling similarly, not enough to change at the centrifugal forces of a spinning driveshaft. Flinging would be the last thing you should worry about. Just clean up real well after greasing and you're good to go.
Gilbert, AZ
But since using it I haven't had any of this grease sling out. I cleaned the previous stuff off just to be sure.
