Drive shaft rotation of H55F vs H41&42 wrt PTO drive - genuine toyota and powauto
SYD AU
Website
www.sourcepoint.com.au
In discussions about why my PTO winch is being driven opposite-wise to everyone else (https://forum.ih8mud.com/40-55-series-tech/198702-pto-install-guidance-please.html) - the PTO drive shaft is rotating clockwise (viewed from the front of the vehicle) and the winch is rolling out in forward gears - I wonder if this has something to do with the H55F split-case transmission that was introduced in 1983 for B motors according to Transmission and Transfer Case Specifications - Land Cruiser at Off-Road.com.
I have an 8/83 BJ42LX (Australian) with the 5 Speed Transmission and the 3B Diesel motor.
Could someone please confirm that I have correctly identified my transmission?
I also have the factory manual for the H41&H42 transmissions - does anyone know where I could get a PDF for the H55F?
I found Toyota H41,42, 50, H55F Transmission Repair Manual | Free eBooks Download!
but I can't get it
Haven't read through your other thread but your cable is wrapped on your winch backwards. On a Toyota PTO it loads on the top.
Your tranny is indeed and H55f and your truck is perhaps the holy grail of Land Cruisers.
Hi lowenbrau, thank you for your reply and confirmation.
The winch was wound wrong - by the PO - probably because that is the only way it can be made to winch in in forward gears - the existing combo of powauto pto and toyota mech winch and drive means it winches in in reverse when wound correctly as you say. Once I had the winch mounted and was waiting for the shaft to be extended (due to having the 5 speed) I pulled the rope off.
That thread is rather long and things only really got interesting once I got the extended drive line back from hardy spicers and found the direction of rotation opposite to what I expected!
