I have a 73 with an aftermarket rollbar. I dont know when it was installed but it has the front hoops and thick angle on the back where it bolts to the wheel wells (It runs the length of the rear wheel wells). I bought the CCOT 3 point belts since I currently just have lap belts that are GM and are bolted to the seat. So if I wreck I will fly out of the window with a seat strapped to my ass.
My question is : Since I dont have the factory roll bar with a mounting point for the upper part of the shoulder belt should I drill a hole throught the roll bar and use a grade 8 bolt and secure the top piece, or should I weld a plate on with a hole for mounting. Along those same lines is a flux core wire feed welding stong enough for securing this plate?
Also on the latch side I am going to sandwich some steel above and underneth the tub in order to drill through and mount the clip section of the seatbelts. Does this sound ok? Anything can be better than what is currently installed but I want to feel safe when I put the seatbelts on.
Pics of rollbar.
Pics of rollbar.
