Drilling Holes In The Frame
in the garage
will this weak'n the frame at all to drill 1/4 to 1/2 inch holes in the frame?
any info much appreciated..................thanx
Doc
Utah
Are you trying to save weight?
Lay off the damn Krispy Kreme's and you'll be better off.
Dry Fork, WV
Yes, but depends on the overall condition of the frame and where. I'm planning on punching a bunch of holes in my frame this summer for cleaning and rustproofing the interior of the frame. Will target the inner vertical side and will stay away from contoured sections the best I can. It's gonna be a chore but it needs to be done.
Cahil
in the garage
save weight!!HAHAHAHAHA!!
seems like i'm adding more and more every day!!!
and it's not krispy kremes,,i'm not much for that particular dog-nut.
just needed to tap a couple of holes for a x-member for my anti-wrap bar. :D
nothing major ;)
South west utah
just use a drill if you torch the holes or weld anything on a frame it will change the properties of the metal. People don't realize it but frames are tempered.
Larkspur, CO
If you have to weld, run the beads lengthwise to the rails, or you'll seriuosly weaken the frame. Ol' Rastle Cock welder told me.
Spokane, WA
Once you drill the new holes, you could sleve them. That will help transfer the load to the frame.
in the garage
thanx for all the info
evryone was a big help
there are exsiting holes i think i'll use for the skid plate.
an just put a couple of small welds in for good measure ;)
