Note: This feature currently requires accessing the site using the built-in Safari browser.
i need that setup...muhahaha
Actually, I don't think it takes much... side stepping the clutch at 5k RPM with an open rear differential (2wd mode) and you can smoke the tires. Once you have the initial traction break loose, it'll just keep on smoking. If that fails, inflate the rear tires up to 60-70 psi. I'm not saying that particular LC didn't have a lot of power, just that it doesn't take much.There is obviously some serious HP increase on the 100 in that video. After driving Christo's 100 w/ a turbo, I'm not even sure that's enough to do that kind of drifting.
they have different tires on it. Probably the semi slick "balloon" sand dune tires they run. 295 BFGs are a heavy beast. As far as serious HP increase, thats not whats needed to break them loose, its TQ...and if you were to say make it RWD and put it in low range...there you go.
the turbo on that Prado was SICK!
