Doors Lock when rear hatch is opened... (1 Viewer)
Charlotte, NC
Does anyone else have a cruise where the doors lock and the lights come on when you open the rear hatch? I assume this is some type of security function. Is there a way to turn it off?
For my 96 model, the ceiling light in the cargo area and the rear door courtesy lights will come on when you open the rear hatch if the switch on the cargo light is in the forward position. If you put the cargo ceiling light switch in the middle position the cargo light won't come on but the rear door courtesy lights still come on.
So the doors lock (or unlock?) and is the engine running or the Key in the Ignition, when you open the rear hatch?
New Jersey
Do your lights come on when the hatch opens?
If you have the port installed RS3000 alarm and you unlock the doors with the fob and it doesn't sense an open door within a preset period of time, the doors will relock. If this only happens with the hatch, then there may be an issue with the switch.
Charlotte, NC
If my headlights are left in the in position, after cutting off when the doors open, then the doors will lock, the chime alarm will come on, the headlights come on and I have noticed the rear I terior
Light comes on but it’s very dim.
New Jersey
I wasn't referring to your headlights. I meant the interior lights.
What happens when you just open the hatch? Do the interior lights come on the same way as when you open a rear door?
