Doors from 1978 FJ40 - will they fit on an early 1970's FJ40?
I have an early 1970s FJ40 but no doors (the guy who sold me the FJj40 - never produced the doors) Have an opportunity to purchase some doors from a 1978 model, but want to make sure they would work on the earlier model. Need Help ASAP.
Thanks!
Your inquiry may be answered quicker if you posted in the
"40 Series Tech" section..
.....1978HJ45
Hi All:
As been mentioned, you have a FJ40, so you should post this question in the 40/45/55 Series section. :)
The hard doors changed in late 1974. So the 1975-84 40 Series had think doors, while the 1974 and earlier rigs came with thin doors.
I do believe these doors can be swapped, but the door strikers, etc, may be different.
Good luck!
Alan
P.S. the 70/75 Series was introduced by Toyota in 1985 as the evolutionary replacement of the 40/45 Series.
Thanks!
yes, they will fit.
change the strikers as noted above. i like the older doors better than the later doors. better steel and quicker window movement.
plus you can unbolt the upper from the bottom and have half doors.
