Note: This feature currently requires accessing the site using the built-in Safari browser.
I thought you had to take the front fenders off to access the front door hinge bolts.
I unbolted froM the door not the body easy
I have mine on pins for an easy swap to 1/2 doors.
X2, use a ratcheting wrench, easy peasy.
^Elaborate with pics.
X2
VT
Just want I wanted to finish off my half door build. Pics please
Pins would be a great idea... I actually still have my half doors.
I think it might be the angle of my hinges. What angle should my top and bottom hinges be set at?
So it lines up | < like that with the rear pillar , called "B".
"A" holds the windshield, "B" is next , and so on. Rear of , handle area , rear should be | | not /| always in line. That Adjustment is from the inside of the pillar, under the dash .
There are four 4 , adjustments , top , bottom, in and out , plus up and down.
Small , loose till known all is correct then lock down and make secure.
Finger tight+ , then recheck , Gravity works , so add a little drop ratio for wear in dropping later.
VT
