My door strike catches had worn severely in on the driver’s side cause one of many rattles, so I got a little creative and thought I’d share with the forum. Maybe it’s a start at giving back some knowledge that I’ve gained from it.
Also, I realize that not everyone has a machine shop so this may not be feasible...but if you do or know someone that does it took all of 10 minutes to set up and mill. This fix is not for the purists and surely others can drill holes more even/square than I can in a hurry. I fully accept that it’s not perfect but neither is my 40 and that’s what I enjoy about it
I thought the plates were totally square and would make milling them flat again easy - they’re not. They’re cast with a slight uphill slope and tapered downward. Figured I wasn’t out much to try it since I was planning on buying new ones anyway. So I began to think about a potentially replaceable surface that would offer less noise but sturdy enough to handle the repeated metal contact. I came up with plastic/nylon strips from Amazon for $7. It’s a 1” x 1’ x 1/8” that easily worked with a saw or other pneumatic tool Nylon Strip.
This is the passenger side before I started and then after milling
You can see the other one I’d already done, since I didn’t know whether or not it would work I never took pictures of the first attempt. Here’s the tapped and shaped product (pardon my poor attempt to counter sink the nylon for the tapered screw heads).
Hope that helps some people, any questions please feel free to ask.
