Door open/closed actuator buttons (2 Viewers)
Montreal, Canada
Not sure what these are called but the ones in my rear door frames are a little finicky and as a result the dome lights don't always come on when the doors open.
Any tricks to fixing these?
Thanks in advance.
:popcorn:
I like :popcorn:
probably not worth trying to fix, they are only a few dollars from dealer, mine were doing the same 4 or 5 years ago, replaced with new, been good since.
How difficult to replace? Plug and play with the new ones?
they come of with just a bolt. i fixed the door switch on mine by spraying some cleaner.worked for a while. i am suspecting pitted contacts in the switch. sanding it down may help if it is cut open.it is a sealed unit.but i think it's better to replace than cut open and fix.
I cant seem to find a part number on toyodiy unless im looking at the wrong section. Anybody know what it is?
