Door and Sunroof Seal Conditioning for my 99
Elizabeth CO
Website
www.grimmperformance.com
Got some real wind noise past the door seal on the PS as well as a leak past the rear seal on the sunroof where it looks like the PO ran a CB cable. Is there a product out there that helps restore or "plump up" seals to get them to seat better?
I've used silicon on rubber to keep it pliable, but if it's deformed like your CB notch, you may need to replace.
The CB notch may be a fact of life. The wind noise from the door is the most annoying part. What form of silicone do you use? A spray lubricant?
Yep, just a spray, not the silicon sealant. Although that would eliminate the problem. :flipoff2:
Yes, and an arc welder would as well. My wife said she used to watch the Dukes of Hazard...
