Door Ajar lights intermittent whenever making right turn, already replaced door sensor (1 Viewer)
Chasing down this intermittent problem where my door ajar light goes off (door light + dash + overhead light) whenever I'm making a right turn with more than 1 full wheel turn. Any ideas what it could be? Already replaced the door sensor with a new OEM one, problem still persists. On a '02 LX.
Ayune
Portland, OR
First questions:
- does it happen when you take a slow right turn as described, or does the truck need momentum to cause the issue?
- have you re-slammed the doors (and rear hatch) to see if it helps?
- which door sensor did you replace? (Assume you mean the door jamb switch)
- test while parked: do any of the door jamb switches feel loose to your fingers, or, is one more easily activated than the others?
